Bug original image since 1.6.x
Hehehe
I have only one antena and one Lnb ;)
Now I do not understand anything.
You have one LNB 1 on tuner A and other LNB 2 on Tuner B or not ??
You can not use two separate tuners on different frequency and different
transponders if you have only one single LNB.
Then what about this?
I do not hear anything :eek:
- I have 1 antena and 1 lnb connected to sat turner A.
- From the output of A to imput turner B through cable (included in the deco)
- Configure turner A y turner B exactly the same way: Type One, Astra 19.2º.
When I run first setup and configure turners (a,b,c) after tuner a and b are deconfigured, and I have to do this:
Menu-Configuration----etc------and save again the configuration.
The second time lucky
Sorry for my poor english.
Regards from Spain
Thanks a lot!!
I think you need to use loopthrough to Tuner A for configuration Tuner B
I think special configuration for tuner B in your case with one antenna does not make sense.
Equal to Tuner A will also work
but you have to test.
Without cable From the output of A to imput turner B doesn´t work (tested).
Thanks in advance...
Regards from Spain!!
This all is normal,Tuner B receive signal from Antenna with this cable
and antenna is connected to Tuner A.
So I have not find bug with all this.
Thanks Matrix...
Now, I'll wait to someone to have the same configuration: 2 sat turners+ 1 dvbt turner (interno) and test this...
Regards from Spain..
