Box: Vu+ Duo 2. Had BH 2.1.4. Updated to 3.0.2 (Oct '16 build)
Reason for updating: was getting some recordings of zero length
Used to be able to connect via OpenWebIF, FTP and Telnet, and now can't :
FTP: get ECONNREFUSED (with Filezilla)
Telnet (dos): cannot connect, and no login prompt
OpenWebIF: get login prompt (good!) but it always just comes back with login box regardless of password
Samba: I CAN see shared folders from Windows (therefore box IP is as it was 192.168.1.110)
What can be done?? I am not beside the box; it is in a friend's house and the only access appears to be via the TV remote and these shared folders.
Why is Telnet not even showing a login prompt? (it actually did, briefly, on next attempt, it didn't)
Vu box and router have been soft- and hard-rebooted.
Perhaps the password needs to be reset - can I do this via the remote?
All help appreciated.
jas
jas
