Dreamplex
Thanks again nunigaia, all my movies are on a linux networked media player "Xtreamer", is there a plugin / addon that I can use on the Vu+Duo2 to watch them on it??
I don´t have "Xtreamer" to test, but google for " XTREAMER+PLEX ", and see if you found anything that help you.
Regarding this: http://www.vuplus-community.net/board/threads/dreamplex.21752/#post-174602, do you have a Windows PC connected on the same NETWORK of your STB ( VuPlus ), if so, begin to install PLEX MEDIA SERVER for windows.
Hi nunigaia.
I dont use my computer's hard drive for streaming, and I'd prefer not to use the hdd in the VU+Duo2.
What, if any, networked media folder setup does BH 2.1.5 allow you to view video from ?
the xtreamer media player has an internal hdd which is Upnp / DNLA / SMB / NFS, compatible and can also ftp , telnet onto it & browse it from the web
At least with XBMC on BH 2.1.5, you can see the entire list of movies on the xtreamer's hdd but they wont play - It's very very frustrating -
I'll just have to google other images before installing them to ensure they can play video from a hard drive that is Upnp / DNLA / SMB / NFS, compatible.
I thank you so much for taking the time out to reply to my queries - - you are not paid enough money !!!
Following on from the post above -
It appears VIX images can playback movies on a mounted linux hdd - so reluctantly I'm going to replace Black Hole with VIX.
Thanks to all contributors for your help to date.
OSD and image Position can be adjusted with the plugin UI Position Setup
First install (enable) plugin in BH Speed Up.
(blue button>> Blue >>Black Hole Speed Up)
Found all these posts very helpful - thanks all. As a dummy, might I expand these instructions in case others get as confused as I did?
I enabled the OSD item in Black Hole Speed Up but could not find the UI Position Setup among the plugins which I'd searched for before starting on the downloadable plugins list a while earlier. At the time that I enabled the OSD item in Speed Up, my box's connection to the Internet was down. Later having ensured that the connection was live, I started the process again. To my surprise (and delight) the plugin was downloaded automatically. Then I was able to run it and adjust the UI position. For me and perhaps other dummies the instructions did not make clear the need for the box to be connected for the procedure to work.
Nice
but BH can use any mounted drive CIFS and NFS for record and playback
I use MYBOOKLIVE network drive for very long time
mount is very easy and automatic with NetworkBrowser in network configurations.
Hello, guys, I tried to install the DreamPlex version 2.1.3 but I'm using B.H 3.0.1.0 OE3.0 in Duo2.
I tried installing by the "manually install ipk" Addons and gave the following information "parse_from_stream_nomallec: Excessively long line at 7.
Corrupt file? "
Corrupt file? "
Install the DreamPlex Ver 2.1.0 from Black Hole Feeds. You should be able then to update it to DreamPlex Ver 2.1.3
Hello,
I have installed Dreamplex 2.1.3 on my VU+Solo2 with VTi 11.
Everything works fine except that when I watch movies, every few minutes appears the system busy icon on the left upper corner and after 2-3 seconds it diappears.
Can I diable somwhere this behavior?
It's just disturbing while you are watching a movie but the movie continue to play normally.
It seems as if a background process starts and stops sometimes...
The "busy icon" appears in "Streamed", "Transcoded" and in "Direct play" mode.
Anyone knows a solution?
Thanks in advance
Michele
Hello,
Thanks in advance
Michele
Sorry mate, we don´t give support to Vti images, you must ask for support in Vti board.
Hello,
I have installed Dreamplex 2.1.3 on my VU + DUO2 and VU + SoloSE v2 but it does not play my .ts files recorded on the boxes.
I have moved the recordings to my pc of available space reasons.
Should add that I have Blackhole 3.0.2.A on both boxes.
Has anyone gotten it to work with the latest versions?
Since I have problems with vu+ software stretches the image far out of the sides and the height so much that I can not configure Dreamplex settings.
Can not see what is at the edges, or see colors settings at the bottom.
Can I change them settings in a setup file?
Since I personally think the font is too small, would like to have larger fonts so it is more visible when to configure the box from the couch.
Hello,
Why are you using dreamplex to play your local files? You can do that with:
MediaPlayer
MediaPlayer2
Enhanced Movie Center
Advanced Movie Selection
MovieBrowser
etc
If you image is stretched you can use OSD POSITION SETUP to adapt the size that the menus fits on entire screen ( make it visible ).
If you are using lastest BlackHole 3.0.3 image, you can install DreamPlex 2.1.0 that is updatable online, after the installation.
@nunigaia, hey
As I wrote, I have moved my .ts files from box to my PC computer and distribute them from there with Plex.
Have had cifs before but eneded work since I installed a small hdd in the box.
Has also had direct recording to PC but then I only have wifi at the moment so will the recordings are not the whole, can be jerky and other defects.
Therefore, I installed a HDD and move from it to the PC. So I have to have a program in the Vu + to see from my computer.
@nunigaia thanks,
ui Position setup did the right job with the image position.
Have tried to uninstall Dreamplex v2.1.3 and then installed v 2.1.0, then updated it on bh server to the v3.1.3.
But it does not work with bh 3.0.2.f image.
Someone who got it to work in 3.0.2?
or do I run into bh 3.0.3 image?
@nunigaia thanks,
I´ve tested with blackhole 3.0.3 version and it works.
Use this file if you want.
Hola buenas noches. Tengo una consulta. Estoy un poco verde en esto.
Tengo un vu+ solo2 con HB 3.0.4 y dreamplex 2.1.0 beta 30...me sale el menu a media pantalla...como se podría poner a pantalla completa??
Get a sync error problems with the index (list index out of range)...also no connection to server... while a token is made on the system and on the plex account.
Dreamplex 2.1.3
last Blackhole image on VU+ Zero 4K , discovert network (bleu bouton in server) dont work
any idea?
