EclipseHD
Yesssssss, maybe a little more transparency to background...
This transparency is 86%, which you cannot not see 100% in the screenshot.
The best usable transparency is between 82-86%
So you can regulate the transparency
If we take 82% then you can not regulate.
Thanks, I'll try your pictures on TV. They looks different on PC monitor.
PS: some beta for testing ;) ?
i am running BH 1.7.5 i used to run this but when i try to add Eclipse skins start 2.0.x
could any1 tell me how to get older skins if possible???
thanks in advance
I do not understand why you're still using such old image
when a new is better and with more features.
We do not have more skins for the old images.
Hello Matrix10,
Thank you very much for your skins, I really appreciate all your work but I like EclipseHD B skin most because of a PiG.
Unfortunately, when using BH 3.0.4.D, switching to skin EclipseHD B (Format 1280x720, for BH 3.0.4.A and up) hangs my VU+ Duo tuner.
Could you fix this problem?
Best regards and Merry Christmass :)
