EclipseHD
Is there any possibility or hope to have these small menu windows "scrolling" from left to right when appearing and right to left when leaving ?
Without the support of in the Enigma coding is impossible
(probably I know the way how to implement with the compromise
and bad workaround)
But this is practically useless in older boxes and performance.
Perhaps in the future on new machines with the real coding.
It is probably time to design separate images for different generations of machines, as the interest today to buy a new stuff is not obvious....... After all, windows 8 does not run on old x286 processors !
:cool: I do not know how much free time do you have
but I do not have it.
They still are not very happy in the house with the time that is now spent on the hobby.
What do you think how much time you need to make a bigger modification of the skin only
not to speak of a new skin , or even new image for 6 boxis :eek: .
Unfortunaltely for you, if I correctly understood, you will have more work as the BH Team will support the coming xbmc box......:grin:
Anyway, back to the main subject : On your skin MX-Z1, the font size you use in green panel for the plugin descriptions is too big : I did change from size 18 to 14 to have the description fully displayed.
Master, would be nice for much users to see updated excellent skin Eclipse hd SB on 2.x.x when You have time for it. I tried this on addons but can not be used on new images.
