EclipseHD
What to do
to make skins for each user separately.
Some prefer ,some others do not
:D
Remove this from skin.xml file
and restart
<screen name="StandbySummary" position="0,0" size="132,64">
<widget source="global.CurrentTime" render="Label" position="0,0" size="132,64" font="Regular;30" halign="center" valign="center">
<convert type="ClockToText">Format:%H:%M-%h.%d</convert>
</widget>
</screen>
But if you mess up image will not start.
Then you have to quickly delete skin via FTP.
So if you do not know better do not touch.
Thanks, but I decided to just let it be like it is, it actually doesn't look that bad ;)
But thanks for the info anyway.
