EclipseHD
Thanks, but it is ok with SE HC.
Do you know which plugin Airplay is correct ? and were can I find it ?
(from raining day in Paris)
Lovely design !
Could you give a little more width ( or reduce font size,...or allow double line) as some longer texts do not fit : for example "Remote Channel Stream Converter "
Lovely design !
This is for now only experiment,
and all this is a lot of work.
Certainly I will not expand the menu panels for so long names
If only one or two.
I may decrease slightly fonts
Or perhaps i will use these android fonts look good.
But the question is whether they support all languages.
The idea of ​​the skin is very good
Unfortunately we have many limitations
like for example the system panel.
I'll see how to solve some things
but I have to make a compromise.
