EclipseHD
Oh yes MX10, all great skins (as usual on you), but from this EclipseHD, until now, my choice goes to EclipseHD SR. :)
All are interesting in their own way
difficult to decide
a ten-minute one, ten minutes the second skin .
but surely this will be the strongest collection i have make.
difficult to decide
Yes you're right, all are interesting in their own way. As I said before, I like them all, and I'm thinking to use all your collection.
I'm a compulsive skins user, specially your's and Army's skins :D , I change skins all the time because I like them all :D
Thank you matrix10 We want something new all skins EclipseHD
The same Something He Change colors only
I love your work
Unfortunately I have nothing new from your point of view,
because these skins are for me the new and the best so far.
Maybe you could use some other skins that you think of as new.
Rgd MX
Once again ,
EclipseHD Series with narrower OSD consists of three identical skins
with the same coding, but in each there is a somewhat different
We have 3 versions
EclipseHD S (Black / Gray)
EclipseHD SR (black / red)
EclipseHD SB (black / blue)
These skins will be on the server, after release of BH 1.7.4
Once again ,
EclipseHD Series with Wide OSD consists of five identical skins
We have 5 versions
EclipseHD (Black / Gray)
EclipseHD R (black / red)
EclipseHD B (black / blue)
EclipseHD E (Epg info in 2xok OSD)
Eclipse SE (Black / Gray )
Thanks Matrix10,
To my point of view the only weak point in your marvellous skin is the picon which looks artificial....
Would it be possible for you to design a shape for the picon which could fit better the smart way you made your picture (like the clock for example) , then we could use that shape to add channel logo ?
Thanks Matrix10,
No is not,
because with this Picon comes to the front.
Of course it depends on Picons.
But this was tested with Picons from our server
used by most users
But just wait to see on the TV screen.
All skins online you can download from image server.
Skins EclipseHD BH 1.7.4 (Black Hole E2)
Skins EclipseHD S BH 1.7.4 (Black Hole E2)
Skins EclipseHD R BH 1.7.4 (Black Hole E2)
Skins EclipseHD E BH 1.7.4 (Black Hole E2)
Skins EclipseHD B BH 1.7.4 (Black Hole E2)
Skins EclipseHD SR BH 1.7.4 (Black Hole E2)
Skins EclipseHD SB BH 1.7.4 (Black Hole E2)
Skins EclipseHD SE BH 1.7.4 (Black Hole E2)
My favorites are EclipseHD SE ,SB,SR
But all skins using the same coding
choose which you like best .
Not from me,
I think not, because we make our skins
that meet the image performances .
Skin task is not to change image .
matrix10 all skins
There is a problem when you press StreamTV
Channel selection and shows the Crash
@MX
I am using Skins EclipseHD R BH 1.7.4 (Black Hole E2) on my Ultimo, and when I use the media player I have no info bar.
