EclipseHD
Definitely my favorite skin, thanks for the work !
Took me some time to figure what PIG monitor standed for (google returned a lot of different content, lol), if that "Picture In Graphic" is the smaller TV screen you got on some menu, don't understand how it slow zapping with infobar only ... but all I need is to try it :p
Because it slows down zap in channel slection panel if you have a PIG
But now the difference is not so great and almost imperceptible
After optimization of the skin and even some coding changes.
Both skins are fast enough
I sometimes use a skin with a PIG and sometimes without.
I like last skins EleganceHD G2/G and Elegance C
The EleganceHD P and I , I'll do the same coding update
as for other new versions G&C.
Thanks for those details Matrix,
I prefer with PIG (and EPG on extended bar), don't see the point of zapping if you can only see the border of image... unless maybe adding transparency but this might alter the shiny reflect effect.
I agree with Pilou, I prefer with PIG, by the reason I like to see channels while I'm navigating through menus and while I'm zapping in channel list, and as Matrix10 said, "now the difference is not so great and almost imperceptible", thanks to our skiners and coders, we're talking milliseconds, anyway, beyond PIG skins, I use no PIG and I like it too.
I don't see EleganceHD G2 in addons panel, or I missed something?
WELLA !!!! :help:
For info EleganceHD skin development will continue under another name.
EclipseHD
That's because some other images have started to use the same name EleganceHD .
Which leads to confusion for some users .
EclipseHD & EclipseHD B & Eclipse HD E
EclipseHD
EclipseHD B Blue
Eclipse HD E event info in OSD
Eclipse HD C (standard no PIG)
Matrix10’s Registered & Protected Graphic
  1. Copyright:All Rights Reserved
  2. Registered:2012-04-07 22:10:21 UTC
  3. Fingerprint:
    d5d70c163f788234765e196a6cbf5823b441c995461f2651cc99148be4a3d014
  4. Title:EclipseHD skins (EclipseHD,B,E)
  5. Description:EclipseHD skins
  6. MCN:C4KTE-CUB41-1FLMR
EclipseHD C (no PIG)
  2. Registered:2012-04-09 08:56:59 UTC
  3. Fingerprint:
    9fd02419fcd0392cdddbe0aff6f62dce25557703553f27e0f72c4df39f30ccc5
  4. Title:EleganceHD C (skin)
  5. Description:EleganceHD C (skin)
  6. MCN:CKKWK-XXT1E-PRE12
Skins for BH 1.7.3
EclipseHD B & EclipseHD C
can be downloaded from the image server
(green button >>yellow>>BH Addons Download Manager >>BH image skins)
EclipseHD & EclipseHD E
will be likely in the next image.
Rgd MX
