EclipseHD
Hi, I have problem that on some channels words are over other. The idea of 2xok epg is fine!
Unfortunately we can not change because some TV channels using only extended info
and some only standard short event info,that is most of the channels,
use one or the other.
A small number of channels use both And then there is a problem that you described.
EleganceHD G2
No, not on the server
Perhaps in some of the following images .
This is too good for only on the server , for me the best coded
PIG skin.Probably the strongest skin so far
because I already use this skin longer
and have no intention to change that soon.
I do not want more to make half coded skins
just because a couple of new graphics
but as much as possible perfect coded skins .
  • Like
Reactions: tae
My Uno is very pleased
Since I've never had a different image on it auser bra although some things do not go
I did something different skin versucvht but not ne me here are the best skins
Since class guys.
How can i download and install EleganceHD G2????
I am a newbie with a Vu+ UNO running on BH 1.7.1
not on the server
This is only the beginning of the same version but without PIG monitor
There is still much to be made.
I have not worked on that vesion without PIG monitor
longer and I have to make coding changes with regard to the current level of images coding.
Furthermore, it shall make the graphics for it.
OSD and players will be the same as in G (grafit) versions.
PIG version will probably be in one of the following images
and it was completed.
The three versions are planned, and perhaps four
1. EleganceHD G (PIG extra OSD with event epg info)
2. EleganceHD G2 (PIG standard extra info in OSD)
3. EleganceHD C (classical no PIG static menu ico)
4. Maybe later, with the dynamic MENU ico.
