EclipseHD
I prefer OSD that is in post nº1, the info bar looks better with the 3D look and round border.
Elegance HD P2
on image server .
EleganceHD P2 (pig) BH 1.6x
Matrix10’s Registered & Protected Graphic
  1. Copyright:All Rights Reserved
  2. Registered:Sun Dec 18 10:02:17 UTC 2011
  3. Fingerprint
    9864f3503cefed38ab33be48c44721302092440ce28e86f7c962b8beb8b1a0cf
  4. Title:EleganceHD P2 skin
  5. Description:EleganceHD P2 skin
  6. MCN:CC469-W9ABX-PANHJ
Thank you very much Master Matrix10, what a wonderfull skin you made (just like all your skins), and thanks too for keep the OSD Infobar that way.
I need a bigger flash for all your skins :D
I wish to you and to your family a Merry Christmas and a Happy New Year.
EleganceHD - I
with EPG
With EPG info in OSD ( 2 X OK button)
You can download from image server.
EleganceHD - I
with EPG
On my vu+ duo work only second screen (EPG info in OSD) i don't see the first screen (normal infobar) and also by pressing 2 times the ok button always see it that.:confused:
