Elegance HD
Where is Prince MX10!
:sad:!
Love to see more of Elegance HD!
:sad:!
RgdZ
:sad:!
a911
Do not worry.
I'm here.
But I do not have much time
But I do it every night a bit on the new version
This will be the fastest skin for E2.
I need to re-code complete skin.
I have to make a base coding not only for this skin but also for future skins
this type
Rgd MX
@Matrix10
First of all let me sincerely thank you for all the hard work put into building skins for our VU receivers.
I do have a question/suggestion if I may, though:
Did you ever consider to build in temperature reading (aside from HDD Temp) into the System Info Panel?
Same question applies to main Info screen?
@Matrix10
To be honest
I think it is unnecessary function that only affected the
speed and space in the OSD.
As far as I know VU receiver has no problem with the temperature
even not at the lowest fan speed.
OK, I can understand the reasoning regarding main info screen, but System Info Panel only maybe?
This would not affect the overall skin speed for sure, but would somehow complete what Uno can offer, information wise.
possible
But then the coder must first change the image coding
before the skin change.
Elegance HD
Elegance HD
One of my best skins
1.looks nice
2.One of the fastest if not the fastest E2 skin
3.transparent (with the possibility of regulatory transparency)
4.Very good readability
5.No unnecessary icons and other elements that only slow down and reduce the visibility.
Copyright:All Rights Reserved
Fingerprint:Show digital fingerprint
74c7c0afa82316b3c853848d30829d8794f8276a83797b66d1227c684f3710c8
Title:EleganceHD skin
Description:EleganceHD skin
MCN:CACP3-DFQHE-RQH5G
Yes i'ts the fastest skin e2,zapping on the diferent menus are hyper fast,zap on the chanels imediat and what is big plus for me is that bright black background with 200% visibility
I tested practicly all the menus i did not see any mistake on it
One thing is sure this skin will stay on my box for a time:)
Hi Mx10,
Elegance HD R overlay on Elegance HD...:confused:!
@ Skin menu,,,they have the same title name,,,,Can not have both skins,,,:sad:!
RgdZ
a911
