Elegance HD
Hi Mx10,
Elegance HD R overlay on Elegance HD...:confused:!
@ Skin menu,,,they have the same title name,,,,Can not have both skins,,,:sad:!
RgdZ
a911
I like both :chair: Rihanna and Beyonce
Ok I will change Elegance HD R
Thanx MX10!
@Elegance HD R...:wub:!
How can we make all Blue go to Red,,,like @Channel Selection high lite par,,,etc,,,!
RED is hot,,:evil:,,Blue is cool,,,,,:cool:!
Rgdz
a911
This I did not understand
What you want to change in Channel list ???
selected white to selected red ???
Explain a little more.
All colors are perfect @ the skin.....:yes:,,,and its really a hyper fast skin,,,,,:shocked:!
Just @Channel selection TV (menu/list)...the line under the name of channel has blue color and @pig the time line is in blue also!
And its nice if they are RED,,,I think....:confused:
RgdZ
a911
RgdZ
a911
Something is wrong
I have two skin Elegance HD R (red) and Elegance HD (blue)
with red and blue buttons
(the line under the name of channel and the time line is different red or blue )
Hi Mx10
I noticed one small error, while scanning satellite blue progress bar does not coincide with%, the blue bar stops at about 90%
generally the skin is ok
Hi Mx10
Thank you,
That was a mistake in the graphic.
Skin update both versions V2 you can download from image server.
Great Work MX10.
Skins really beautiful and fast ! !
If I may suggest, you can make more visible (Clearer) the current program progress bar at info bar.
This will help when viewing service with small TV.
Great Work MX10.
Hhehehhe thanks @sakisdvb
I have make this skin on Sony bravia 26 inch LCD TV which is on my desk beside a PC monitor,
and the current program progress bar i can see from a five meter. :shocked:
I did not want to use bold strong color for progress would not fit into the whole OSD idea .
But thanks for the support and comments in my work on the skins .
Rgd MX
I recommend this skin especially for those who use the VU solo.
because it will enhance the image work and free resource for other in the image.
Of course it applies equally well to other boxes, but they can make use of the PIG skins.
Hallo. This skin working with BH 1.6.6? And how can I install it. I do not see a downloadable attachment.
Thx
Skin Update Elegance HD R V2
Change :
Update for all red buttons and bars .
Now the color is more red
change progress bar in channel selection.
A FANtastic skin,,,fast, clear,,,,and over all I like the RED lips stick of Beyonce,,,all over my TV Screen,,,,,:evil:!
I will be enjoying it for a very long time!
:thanks:MX!
RgdZ
a911
