Enhanced Movie Center (EMC)
Hello,
I find this extension very good. Only a suggestion (taken from other receivers): it would be more comfortable to have a way to rapidly go forward or back with direct access (for instance using P+/P- as other buttons are already needed to perform other functions).
I know it's possible to jump by 1/3, 4/6, 7/9, that's just something, but it's not the same than moving cursor fw and rev directly, like in other receivers or PC players even because the jump are fixed by the configuration: to change the you have yo re-configure them. Direct browsing is at your will.
Finally, the ultimate features would be having also a little preview during this fast browsing, like some players or media centers do.
Anyway, EMC is already very good, in my opinion! :-)
For back forward use your remote numeric keys 1, 4 and 7 ... and fast forward 3, 6 and 9, try it and enjoy.
EMC is not working on BH 2.1.5. When starting EMC it's not displayed at the screen. You notice EMC is running by checking VUs display and when pressing Menue.
Any Ideas?
Model: VU+ Uno
Any Ideas?
Model: VU+ Uno
i have this problem.... beacuse when im press R in remote control the {D-} is showing on front panel.
on B H 2.1.5 please help me. my box is DOU2
v 3.7.4 the lastest version
1) - Have you installed previously v3.0.0. ( If so, uninstall EMC --> Addons Uninstall ) and reboot your box!
2) - Install EMC 3.7.4 beta ( restart enigma2 ) --> after that go to Setup / Plugins, and config EMC.
3) - After that you can acess EMC ( By LONG PRESS BLUE BOTTOM )
Note:
4) - If you have not maded the config setup of the plugin on -> Setup -> Plugins --> You must do that!
If this version don´t work, you can test other that give you subsupport to subtitles ( download and install from here ):
Install Python --> http://www.vuplus-community.net/board/threads/external-player-in-xbmc.21286/#post-166067 ( only )
Install EMC and Subsupport --> http://www.vuplus-community.net/board/threads/external-player-in-xbmc.21286/page-2#post-166897
Note (2): You must config EMC and make your SETTINGS on Subsupport plugin.
Is it possible for an update to this great plugin to make it compatible with the 1920*1080 skins made by Matrix10?? :)
