Enhanced Movie Center (EMC)
Hi i'm using PLI image and for me this image is the best and why still EMC doesn't work on this one ??? Tkanks .
Is it possible to move the infobar to the top of the screen or make it disappear during the pause function? I don't want subtitles to be covered by the infobar when I play the pause key.
Sorry, but don´t understand your issue. When you press the pause on playing, what for you need subtitles?
Hello, I have the same request if possible, sometimes I should press pause to read entirely subs that go fast, unfortunately every time I pause the infobar appears and hide them.
It helps me to focus the projector more accurately. And rarely, when the subtitles are been shown too fast, I need more time to read them. After all, when you press pause, the infobar should indicate the actual time of pause and the progress bar of the playing time, instead of this it indicates nothing, so it's totally useless to appear. (I hope my english was clear)
Hello is there any way to solve the problem that causes when I see a movie with no epg and I stop it. It doesn't remember the point I leave the movie? Thank you
Post the version of Enhanced Movie Center you are trying to use, and the image you are using on your STB.
Your Vuplus STB model?
Emc v3.7.4beta2
Vuplus solo2
Bh2.0.9
Your Blackhole 2.0.9 it´s an outdated version ... Install on your STB ( Solo2 ), any new image Blackhole 3.0.1 or Open Blackhole 0.1.
It´s just time to upgrade and to have support. Sorry ... but i can't test if the new Emc v1.0 from the feeds, works in this image.
i tried that version and it does nothing with latest BH3.0.1 on the Ultimo had to go back to 3.7.4
It does nothing, how? Don´t work? Gives GSOD? Gives error when installing? Blocks the STB? I can´t configure it? Doesn´t appear on plugins?
Does nothing for me, it´s the same than report nothing.
that's what i said does nothing appears in plugins tried configure it like i always do and it does nothing
Best regards Thijss
Best regards Thijss
Did you have configured it to show in extensions menu?
If so ... Press long blue button ... Extensions Menu --> Enhanced Movie Center should be there.
I don´t know so far ... what is your issue!
If you want help, point us in the right direction ... what you expect to do ... instead of nothing? :confused:
Best regards Thijss
this problem did i have before that when i installed the plugin it showed up in plugin and i was able to gonfigure it but it didnt start, But now it works fine in blackhole 2.17 and open blackhole , so it should work in 3.01 . but havent testet in 3.01 , still use 2.17, you coult test it in 2.17
Regards Seth
Regards Seth
Best regards Thijss
I have tested ond Duo2, this should work, in Blackhole 2.1.5 ; 2.1.6;2.1.7;3.0.0;3.0.1, and of course Open Black Hole 0.1 .
Note: I´m talking about last version on the feeds, packed 26.11.2015, Enhanced Movie Center v1.0git20151126 .
Uninstall the previous version and install the new one from addons feeds.
With the same settings from the 3.7.4 beta (because I found out that uninstalling whatever version of EMC does not delete the personal settings), I have two problems:
1) even though the setting about the "minitv" is on, the TV frame disappears (but not always) and
2) when I close EMS the TV does not get back. I have to press a channel number to see again it.
I'd like to delete every settings after deleting the plugin to see what happens with the original settings but I haven't found the files or folder where EMC stores them: can anyone tell me that?
/etc/enigma2
look for emc-*.* files
and
settings
in the same folder ... edit this file .... there will be this files:
configuration entries:
config.EMC.extmenu_list=true
config.EMC.movie_show_cutnr=true
config.EMC.movie_show_format=true
config.EMC.movie_picons=true
config.EMC.movie_cover=true
config.EMC.autosubs=true
config.EMC.sublang2=en_EN
config.EMC.sublang3=es_ES
config.EMC.sublang1=pt_PT
config.EMC.skin_able=true
config.EMC.movie_finished_percent=100
This is my EMC config entries ... yours should be different ... but is the same ;)
Hello,
Very nice plugin...but how i can't have any covers from database IMDB?
There is always "cover not found"?
I need to tag my video or what?
Thanks!
