Enhanced Movie Center (EMC)
you not change font, you must convert subtitle to UTF-8 with signature... this work for croatian subtitles and šđčćž
btw. how to set autoload subtitles?
There is another issue, still. Even if I installed the last release (from Jan, 31st), it still happens most of the times (but not always) that loading EMC the TV in the PiG stops working (it freezes and gets mute) and then, when I exit EMC, it doesn not even restart automatically. I have to change channel in order to make it working again.
Enhanced Movie Center 4.0
20160229
* Fix for silent exception in log file, 'purgeExpired'
* raised EMCVersion
* next time before you break working code on Dreamboxes check if your changes are really working
- keep this code out as long as it is not working, try/except is NO
solution as it is not working
" Deleted IPK because it was not installiing correctly "
THX @betonme
I installed it as usual but there are some errors and, after the reboot, the plugin is not present and so is not working.
Can you try this one?
And give us your FEEDBACK, thanks ;)
update:
  • Fix for silent exception in log file, 'purgeExpired'
  • Raised EMCVersion
  • Next time before you break working code on Dreamboxes check if your changes are really working
  • Keep this code out as long as it is not working, try/except is NO solution as it is not working
Installata e questa funziona.
Però continuo a sperare di vedere risolto il problema del freeze del PiG che avviene quasi sempre e che poi costringe anche a cambiare canale quando si esce da EMC.
Tra l'altro il file nel #124 faceva vedere per un attimo, durante l'installazione, le righe descrittive in cui era scritto 3.7.4 mentre questa fa vedere correttamente 4.0.0.
I wonder if I'm wrong remembering that EMC (3.7.4) used to be able to add marks to files different from the .ts recorded by the VU+ (avi, mkv and mp4) or if it is and was only able to save the "last" mark so that is possible to restart from the same point.
The last EMC doesn't seem to add marks but also the 3.7.4 beta (that I installed back for a try) doesn't. So my memory is wrong? Or does it depends on the codec used?
I also tried to compress .ts recorded by the VU+ with Handbrake with many different settings but, unfortunately, any of them makes a file where it's possible to add marks. Is there a way or a kind of codec/file that solves this issue?
Hello,
it would be nice to have an option (if not even make it a default) to hide the . files or folders.
I access my folders with OsX and it creates the .DS_Store and other similar kind of indexing files which are normally hidden but shown by EMC.
I use a bh 3.0.0 for my uno and sens i upgrade my bh the EMC crash every time i Cant open it when i puch the boton its give nothing, can any bady help me ?
Hello,
Someone replied me to ask to coder but this thread, I suppose, is the "official" one for this plugin. So I renew my question, in case it is not a hidden option or something to edit in its configuration files.
Hi, i am using 3.0.3 (M or N) on my ultimo 4K and with EMC the display is very very small in the left edge of the front panel, how can i enlarge that?
