Enhanced Movie Center (EMC)
If you meant, "I'd like to change the button to launch EMC", the Red button is not possible to use. Choose another button, like Radio, for instance.
Hi.
Feature request - is there a possibility show film series - added automatically in virtual folders?
Or maybe it is implemented already on EMC, but i don't know how to enable this valuable feature for me?
I Need a Factory reset of the EMC, what do i have to do?. Delete and reinstall is Not enough, because my settings are confused.
1) Uninstall it ... by using your RCU ( remote control unit ):
Press <GREEN>; <YELLOW>;
Choose from the list: Addons uninstall pannel.
Restart your STB ... and reinstall it.
2) If not solve this way ... try:
opkg remove enigma2-plugin-extensions-enhancedmoviecenter
reboot
Reinstall it.
3) If not solves your issues even with this methods:
Run 1) or 2) ... the same way.
Ftp to your STB ... and edit the settings file under:
/etc/enigma2
Remove all the entries lines there related to enhanced movie center ... close the file and save it ... and reboot your STB.
Example of the settings entries:
There is only one thing with emc and have to select subtitles all the time when a movie is selected it like it dont keps setting. Only emc 3.74 works with subtitles and on github dont bother about it.so can somebody here take a look at it.
Regards
@nunigaia thank you, but it did not work. I uninstalled the EMC with the option 1), after that reboot, after that i deleted all the EMC points in the settings in etc/enigma2, reboot again and after that installed the EMC with green and yellow again, but all the old settings are back, big letters, no listings in last records etc.
Any other options?
Thank you in advance.
Hi!!!
I have a VU+ Zero 4k (ARM based) decoder with BH3.0.5 and i´ve installed enigma2-plugin-extensions-enhancedmoviecenter_4-0git20171129_all-zip, so i see the config plugin app, but I´m not cappable to run it!!!! I configure tv-button to start it but when i press it nothing happens...
Any Help?
Hi!!!
Any Help?
Use PVR button. ( by default is setted to VIDEO button ).
Just installed ECM from ADDONS menu in a fresh Blach Hole 3.0.5 installation for Duo2 and it does not start.
Does anyone know what can i do?
