Moderator
I know what I'm doing and I'm in trouble is because something is wrong not because they do not know what to ask and what I do ... before asking something tested in other ways to see if it works , I'm no novice in these systems linux so I went administrator and only founded the largest Portuguese forum for research . I believe that the problem is a plugin that was previously installed and you do not support , so far so well . What I ask is that BH pictures were giving problems with clean installation , even getting into parameters of manufactures in VU but it seems they do not understand what I say.
Ok ... you don´t have a hdd .
Reboot your STB ... with all usb devices disconnected.
If the image crash´s ... by ftp ... navigate to /home/root.
There you´ll find the enigma2 crashlog´s.
Uninstall any "strange panel" too from your STB ... if you have it installed.
Note: Post the crashlog´s here.
Thanks
