FPGA upgrade + 1.78 = DVB-T issues
Wiggy9
I rescanned all tuners (2xDVB-S2 + 1xDVB-T), upgraded my FPGA, and then installed 1.78 on my Ultimo.
Result, I have intermittent picture tearing and pixelization on DVB-T channels. It reminds me of what it was like in the early days of DVB-T support on my Duo using a Hauppage USB tuner.
This was fine before the upgrade. Anyone else having issues? The terrestrial channels in question are Irish.
Wiggy9
This was working perfectly with the old firmware + 1.72.
Can anyone offer some troubleshooting advice?
Is it possible to revert the firmware?
Should I try driver update?
Or just revert to 1.72?
Wiggy9
I don't know if this is relevant, but on any DVB-T channel, AGC seems to constantly vary between 2% and 94%.
SNR is a constant 99%.
Wiggy9
Rolled back to 1.76 and 1.72, but problem still there.
Is there any way of rolling back the FPGA update?
Matrix10
As you can see no one has reported this problem.
I do not believe that the problem is image and drivers
but your DVB-T tuner or reception.
Something has changed in the meantime ??
Nice Monkey
As far as I know the FPGA upgrade process is in fact just a replacement. You should be able to down/up grade at will.
In fact it is a pity that the version level is not tracked.
Doing a "show info' should report the FPGA version being active. Is this something that can be added?
Wiggy9
Thanks for your reply Matrix10.
As far as I can tell, nothing changed. Everything was working fine last week, right up to the moment I started the following:
1. Aquired updated sat.xml
2. Did a full scan of all tuners, and updated my bouquets accordingly
3. Made a Personal Backup
3. Updated FPGA
4. Flashed with 1.78
5. Restored Personal Backup
Plugins in Use:
1. Suomopekia
2. Cool TV Guide
3. AutoTimer
4. Startup Service
Does anyone know where I could get the original FPGA files?
Nice Monkey
I have 4.2, 4.4 and 4.5 saved for UNO. Previous versions attached.
  • VU+ UNO FPGA v4.4.zip
  • VU+ UNO FPGA v4.2.zip
Nice Monkey
Wiggy9
Thanks for looking into this Nice Monkey.
It's good to know that the FPGA's are different.
Would any BH team members be able to obtain the ooriginal FPGA code from Vu+?
mmattys30
yes i did a upgrade on both my ultimos and they both have the problems of stuttering on lnb 2 so cant recorded or watch 2nd chanel if recodeing on the first one and i have never ever updated my fpga as i dont no what that is
Nice Monkey
Interesting. Your problems are probably caused by the fact that you did not upgrade FPGA which is mandatory. There is a Plugin installed standard to upgrade FPGA. Just download from VU+ Support and follow instructions.
The others have problems with DVB-C/T tuners because of upgrading. Different problems.
Wiggy9
I now believe that my problems are cause by the DTT signal being too strong. Going to try and attenuate it over the weekend.
I noticed that previous backups were using a different DTT transmitter. My aerial can pick up three.
Strange how the problem only arose when I updated the FPGA, but I guess it possibly improved reception enough to tip me over the edge. Here's hoping anyway......
