Greek Characters Problem
when i go to Black Hole E2 Downloads everywhere i click (screenshot.jpg)
i get Connectiob Failed (screenshot2.jpg).
I didnt change anything to the image i just install it as usuall from usb.
The only thing is working is plugins (screenshot3.jpg)
which there is not any skin with the name you call it.(screenshot4.jpg)
do i do anything wrong? does screenshot.jpg works for you?
I am currently at work.
So I'll briefly.
You must check your interenet connection here because something is not working.
Our image server works perfectly.
internet is fine. i can connect to other server.
i event tried multiboot. the same with image 1.7.1 and image 1.7.2.
take note that my image is the image of ultimo not duo. i dont know if there is any different in this two images. maybe is bug of ultimo image.
fix it.
my provider dns did not find your servers so i change the resolve.conf and it is working the plugin server. i installed your skin it looks nice but still the Media Player list show it like before.
Then ,I think that the problem is font / code tables that are used to write the name of the file.
I have use winXP with English language to test.
I will figure it out what is wrong. you gave me some hint i will search them more myself. I am sure i will fix it.
also this is not major problem the major problem was the lcd screen and the plugins server which is fixed now.
thank you matrix10 for the support and all the time you spend for me.
