Help for a Newbie solo2
moatboy
Hello all I have just brought a VU+solo2, got stuck a few times, it came pre flashed with BH, I also had to aline my motorized dish, anyway plugged it all in went to 1 west but could not get a sausage so more research, I download a channel list and with dreambox edit sent it to the box and wohoo got a picture locked the dish up all good but now the dish wont move when I select a channel I have it set on tuner A usals and tuner B equal to A. it will move on satfinder but not when I change channel, the only way it will work is if i un configire tuner B.... also need some help with the next step how to get and set up and use ****** a mate has given me a line............. any help would be gratefully received.
here is my set up
1 meter dish Trac and the motor is a motech 2100
i think its the latest BH got the box pre flashed from world of s............
my post code is LE77FU and at dish pointer i get lat 52.6733 and long -1.1948 and as the long is a minus i have read that i have to subtact it from 360.00 so what i put in for long was 358.805 west and lat 052.673 north
angelofsky1980
BlackHole Driver Specialist
here is my set up
You haven't read our Board Rules.
Remember to read it. You have now 7 days to do that: you will be banned.
Remember also that Vu+ boxes (ALL BOXES) should come with ORIGINAL VU+ image and not customized with a specific image or with specific image and ILLEGAL content/emulator or so on.
Thread closed.
