Try another USB stick,if you have not already tried.
But strange is that you can not run BH image.
It is possible that the USB stick was broken or something like that
When you installed VIX.
But to be sure try with another USB.
Personally I have not done this with vu boxes and so dont know how to but im sure there will be a way.
Im sure others with more expertise will also see this thread and let us know if its possible
Well solo 2 not boot from USB stick.
You should install image with/from USB stick.
I hope you hit PWR button when install from USB stick ??
Unplug all connected to a box.
1.FORMAT USB Stick on your PC FAT32
2.Unzip BH image
3.Copy all folders and files on the USB stick
3.switch box OFF
4.Flash with USB stick connected on FRONT USB connector (switch box on)
5. press PWR button
2.Unzip BH image
3.switch box OFF
5. press PWR button
Mistake....should have been ext3 from the flash image itself. There is a howto install meoboot in the How to section. You have probably corrupted the flash image.
Sorry, I formatted the usb from vu + box EX3 and on the first picture turned on but not vti. but I update image vti and after update box began to hang. it would not boot up. only booting
2.Unzip BH image
3.switch box OFF
5. press PWR button
i have done everything that you said to me, but it did not start, can you see the pictures i have posted earlier? it is on page 1 pleas help me , can figure out a new way to start it. i have been trying it for 3 days and it wouldn't start
I also use MeoBoot at the moment and everything works fine.
I have already made so far at least twenty times images installation
and everything is OK.
I do not have bootloader .
I do not think the problem is bootloader.
If you see the picture BH image is booting.
I think it can be only something related to USB stick or USB ports.
Of course I'm not 100% sure.
