HELP!! solo2 won't starts!!
You should still have ftp access so just remove the following then you will be able to flash.
/media/meoboot/MbootM/MbootUpload
/media/meoboot
/usr/lib/enigma2python/Plugins/Extensions/MeoBoot
My box started to work again, thanks to everyone who has helped. If you have the same problem you should follow a911 tip, it works perfectly
