how to flash a vu+ Duo2 by USB.
guardian63
Need some help!
When I try to flash an new Black Hole image, after insert a formatted usb with it, in the front panel doesn't appear the message update, and then loads the old image (how its corrupted, only shows a green screen when it tries to load the black hole gui). Does anybody knows how to solve the problem?
Thanks in advance
ObiWan
Vip
Hi
first of all try another USB pen. In my experience 90% of problems is due to lack of compatibilty in these devices
guardian63
I have DUO2 CFE and I have tried severa usb pen drives.
The VU+ DUO2 also have a internal hd with 2TB.
Need some ideas.
Thanks in advance
Mick12334
Moderator
What was the last image installed?
Do you mean you have a VU+ Duo 2, with the latest CFE v2 bootloader installed?
http://www.vuplus-community.net/board/threads/duo2-cfe-bootloader-update.13413/
Are all your USB pen drives the same make?
You can try diconnecting the internal hard drive, by just removing the top cover, disconnecting the cables, then attempting the upgrade again.
Make sure you have the correct Black Hole, or Open Black Hole, image.
Once unzipped you should have a vuplus folder, and inside should be the duo2 version.
Format the USB stick to FAT 32, load the vuplus folder.
Switch off the VU+, at the rear.
Insert the USB drive into the front USB port, behind the pull down flap.
Switch on the rear power switch, and hold in the front button, next to the USB drive, until it recognizes the USB and starts flashing.
Any other usb devices connected while you are trying to flash the box?
Sent from my Samsung S7 using Tapatalk.
Bonjour,
Je viens juste d'acquérir mon décodeur Vu+ Duo2. Je suis noviste et ne sais pas comment m'y prendre pour le configurer. quelqu'un saurait m'aider à le configure? ou mieux m'envoyer un tuto de configuration en français. merci
