How to install MediaPlayer2 - Updated 07/09/2016
You only can acess your movies via network, right?
If is the case take a look to this guide and test ... as i told you on previous posts ... i don´t have ... and i don´t play movies over network ... not even i use XBMC to play movies ( as i have a internal HDD on my DUO2 ).
I prefer over network --> move my movies to HDD with FTP tool, and play them locally!
but take a look to this guide ---> http://www.vuplus-community.net/boa...ws-7-hdd-movie-folder-with-your-vu-box.13258/
And adapt at your own and particular situation.
Note: Yours XBMC is working --> your acess to network via XBMC is not!, i think!
WD My Cloud is connected on router and i have acces via my network, it work on Open Black Hole but not on XBMC, i prefer my hdd on router because all is there. My internal HDD STB and My HDD USB have a small memories, i use the internal hdd only for recordings.
I want to have acces of my WD My Cloud direcly on XBMC, it most simple for me but xbmc dont want to laaunched. I can't to deplace any movies to my internal hdd.
but if it is a proble from openblackhole, no problem[/QUOTE]
I can not find XBMC folder in /usr/lib/enigma2/python/Plugins/Extensions on BH 2.1.6.1. Do I have to download this plugin from somewhere else?
You can use Mediaplayer2 and Subssuport if you like, as your default player, but you can´t use and don´t search for XBMC on your STB, because there´s no XBMC for first generation Vuplus STB ( Duo, Ultimo, Uno and Solo ), dued to hardware limitations.
Instead of Mediaplayer2, you can use too Enhanced Movie Center or Advanced Movie Player.
Best regards
Best regards
Thank you. But I see devices with one core to be running XBMC without problem.
Hi,
I've upgraded my hardware from Dreambox 800HD se to VU solo se v2 so I could also get rid of my htpc with kodi/xbmc.
It starts fine on my VU, I added paths to my network storage drive, added the folders into xbmc path, but when I try to play any movie the screen is just black. nothing happens. The player launches, but that's it. no sound or picture. In Open Black Hole 0.1 I have uninstalled media player and installed enhanced media player. But still nothing. Now it even starts in different resolution, so I see bottom player controls in the middle of the scren..
any ideas?
Do you think Xbmc will also be available in 1920x1080?
Hi,
1) - any ideas?
1) - I dont´t use XBMC over network!
2) - Are you talking about XBMC skins? Afaik we have 1280x720p resolution, but for skins, with mediaplayer2 and enhanced movie center, you can handle movies 1920x1080 ( full hd ), without any problems.
Note: You can try with DLNA BROWSER and search your Media content over network!
I've installed media player 2 but every time I open anything on xbmc it defaults to the internal player even with selecting e2 player is there anything I need to change in playercorefactory.xml to force xbmc to use media player 2?
You need to put the plugin.py file --> download the one, regarding you using FullHD skin ( 1920x1080 ) or HD Skin ( 1280x720 ).
You can found this files on --> http://www.vuplus-community.net/boa...mediaplayer2-as-default-player-on-xbmc.23381/
Take a look to the guide, there you are noticed where to put the file plugin.py.
Upon upload this file to your STB --> Restart enigma ( GUI ) --> and enjoy!
I have two problems:
1) When i watch three videos on xbmc and i left to return to Open Black Hole, i have like a filter greyish on the channel and when i click on ok or menu, the lumonisty is ok and when i click exit for to watch the channel, i have the filter greyish, so strange
2) when i left xbmc, i have automatiquely the menu plugin, it is possible to remove that ?
