HowTo Connect your PC to your Vu+ box (with FTP)
Ok. I thiink i understand.
So theres no need for a LAN.
I just need to coneect to vu+ with my router. Check my IP on the vu+.
After that on my pc with the ip i can connect directly to the vu+.
My pc has a wireless connection, do i need to use cable to connect the router?
No, wirelessly or cabled, your PC and your VU+ are part of the same network. But you have to configure BH. Actually, after first boot, it does it, more or less, by itself.
You can do or verify the LAN configuration by
SETUP/SYSTEM/NETWORK
After this step, it depends on what operative system you use (OsX or Windows) in case you want to save your settings or perform other useful actions. But many operations can be done also from your browser through the same IP address of your VU+ because it opens OpenWebIf, a web-based panel.
Otherwise, under OsX I use iDreamX and DreamboxEdit under Windows (occasionally).
Hi.
Anyone knows how to change the FTP and Telnet ports on the VU+Zero with BH image? This will help connecting to the VU from external location more securely.
Thanks
agrima
:thanks:very well explained. you have no idea how daunting this can be for the absolute novice starting out. the amount of searching and reading that is needed is phenomenal. not everyone is born with an electronic brain.
thanks for that anyway
Hi Is there any way of a direct connection PC to Solo box? I noticed a Serial comm among other interfaces, is it possible with a cross over cable?
Hello guys,
I've just got a new VU+ solo2. My friend has the same one. At my friend I can open the VU+ hard drive like a network drive on the Mac OSx. But I can't open my one, on my Mac. My vu+ can discover my Macbook, and my mrs notebook, but our computers can't discover my Vu+ box. I have checked every settings, such as network > shared driver.
And also I can't open my box via ftp. I have tried everything. I have checked everithing.
Anyone any idea?
Many thanks
What is your image? If BH or OBH, have you checked if FTP, NFS and Samba services are enabled and running on your image?
Ftp running, nfs running, but im not sure about Samba. I havent seen samba, but maybe i havent look properly. I check it when i get home.
But i still can't connect via ftp.
Many thanks
Looks like i find the problem. My samba is stopped. ( and my friend's samba is running )
But when i press the start button nothing happens. I can change the autostart, but i cant start samba. So annoying.
What can I do now?
I had a similar problem with FTP service. There is an experimental way to solve that but if your box is new and you haven't done much work there, the best thing is to reflash it.
Otherwise you can try to flash only the kernel: create the usual structure in your pendrive (vuplus/"name of your box") and there put only
kernel_cfe_auto.bin
reboot.update
But, I repeat, is unofficial, so don't kill me if something goes wrong ;)
And, anyway, just in case, perform a FullBackup of your current situation to be able to get back to this point.
What about using VU+ Control Centre its made just to do this. Great for backups etc
First of all this software is only for Windows and he's got a Mac. (Incidentally, I can recommend iDreamX for many kind of operations).
And, above all, if some service is not running you can try whatever: it won't work.
GUIDE TO SIMPLE CONNECT BY FTP TO VUPLUS STB´S WITH YOUR PC
1) If you don´t know the IP address of your STB, you can found if connected to your network using the simple and follow software:
Advance IP Search ( Google for it ) and install on your PC
As you can see ... on my network the IP of my VUDUO2 is 192.168.1.3
I can connect with FTP ( File Transfer Protocol with it ), using:
Most used:
1 ) - Dreambox Control Center
2 ) - FTP software like Filezilla or CuteFTP
3 -) Directly on Browser ( Firefox, Internet Explorer, Opera, etc )
Case 1:
Via Dreambox Control Center
Connection: PC -> Router -> STB
Or direct: PC --> STB
On the first image you can view the IP of my PC ---> 192.168.1.4 and VUDUO2 ---> 192.168.1.3
Case 2:
Via FILEZILLA
Case 3:
DIRECT CONNECTION
Via BROWSER
ftp://192.168.1.3:21 ( in my example, cause the IP of my VUDUO2 is 192.168.1.3 )
In engish
Nome de utilizador = User Name
User Name: root
Senha = Password
Password: dreambox
ftp://192.168.1.3:21 --> In my case the IP of VUDUO2
Click <OK> and you found the next and last screen of this tutorial:
Direct connection established with browser.
Hope it will be usefull for all that don´t know how to establish connection via ftp
Hi thank you for excellent guide.Help please i am using filezilla and i go to network, VU duo etc,open etc but cant find cc cam configuration any ideas where it could be hiding i have just flashed blackhole 303 working fine on free channels. regards Phil79
Hi everybody! Is it possible to set FlashFXP to transfer between two remote servers when these two remote servers are two hdds connected to Vu+
meaning that they would both have the same ip address and just different paths such as media/hdd and media/usb.
Thanks in advance
