HowTo flash/update Vu+ images
Hi all, I have Vu+ Duo, I try to install Images 1.7. or later but the receiver not accept more than 1.6.5, any one can help me? thanks
hi HELP please, I tried to install Blackhole via USB my vu solo2 is now saying Starting
even if I turn it off an back on its stuck on Starting
any advice?
any advice?
As written in the first post:
if, for any reason, the upgrade fails, first disconnect any USB devices connected to your Vu+ and then try again to install the new image.
If the upgrade fails again, try to use another USB stick.
I did but I think its a problem with the booting because as soon as u turn it on it says Starting
Hi!
What is the brand and capacity of your USB stick ?
Is the USB stick is formatted as FAT32?
Check the exact size of the file to download?
Finally is you unzip it all in the USB stick?
Once everything is in order,:
Turn off the VU+
Insert the USB stick in front of the VU+
Turn ON the back button and wait ....
To reboot 5 .. 4 ..... 3 .... 2 ..... removing the flashdisk
thank you.
Hi!
Turn off the VU+
thank you.
thanks Fantome
I am using SanDisk Cruzer usb stick, fat 32, unzipped file to the usb, but
when I turn the box on its stays stuck on Starting, does not move from there, I think it could be a booting up problem
thanks Fantome
Have you any usb or hdd connected ?
Hi. I have now image 1.7.8. my Ultimo.
I'd like to upgrade to this latest version. What should I take into account in particular?
How do I do it?
Thanks.
How do I do it?
Thanks.
Never mind....it does not matter ... I would not have wanted to update this image .
