Hungarian Thread
Hi guys,
I have made an upc-digi fav list updated all working channels today and categorized for my taste. I also made a picon pack for this list.
I was lazy to collect the correct picons sorry about this. The size is quite large.
The picons are transparent thanks for chocholousek's bulk. I think looks good with every skins.
If you have any questions just let me know.
Best regards
Szia Tibi!
VU+Solo2-őm van VTI-vel. Már régóta a te encoding.conf-odat használom, a helyes karakterek megjelenitéséhez. Most annyi gondom lenne, hogy a DigiTV-és 11823H TP-én lévő csatornákat sajnos még mindig más karakterekkel jeleniti meg a BOX.
Ezt mi okozhatja?
M1 HD
TV2 HD
Digi Sport1 HD
Digi Sport2 HD
Digi World Hungary HD
Szolgáltató: DigiTV
1W 11823H
TSID 0x000d (13)
ONID 0x0001 (1)
Ezen a TP-én még 2db román HD csatorna van.
Néztem, hogy bejegyzésként ennek a TP-nak az adatai benne vannak a encoding.conf-ban.
"13 1 #11823H - 1W - UPC Direct"
Próbáltam HEX-ában is megadni, hátha az segit, de semmi változás.
0x000d 0x0001 #11823H - 1W - DigiTV
Lenne ötleted, hogy ezt hogyan lehetne korrigálni?
Üdv.:
Ákos
Update: I foud a solution.
I red on Internet the DigiTV has their own channels that broadcasts EPG not at all following the DVB standards.
They use 8859-16. This is why if you use charset from "hun ISO6937" does NOT work for their own channels.
I must put this line to Tibii's "encoding.conf":
13 1 ISO8859-16# INTELSAT 10-20 1°W DigiTV 11.823 H
or HEX format
0x000d 0x0001 ISO8859-16# INTELSAT 10-20 1°W DigiTV 11.823 H
And very important to delet these lines from Tibii's encoding.conf:
13 1 #12512V - 1W - UPC Direct
You can simly search "13 1" in database.
I searched after "0x000d 0x0001" too but there are not any other lines with these entries.
This is my corrected encoding.conf:
1.) extract encoding.rar
2.) copy ancoding.conf to the box to the usr/share/enigma2 folder via FTP
3.) restart the box, not just the GUI
Nice job. You've solved my old problem! :yahoo:
:thanks:
Is there a way to fix the hungarian special chars issue in file names? Even files are created under Linux, or Windows, they are displayed fine by a lot of TV-s, (If I connect the USB stick to TV), but no by STB (with BH). What if I put a HU file in var\lib\supported.d folder, filled with "hu_HU.UTF-8 UTF-8" ? Does it helps?
Just use winamax69's encoding, lovely stuff, working properly.
If you have an update the encode need to be copied again.
Sziasztok .
Vu zero+4k használtam VTi vel digi alatt , most upc -s lettem, black hole-t raktam fel rá , meg tudjátok (persze ,hogy meg) mondani , hogy mit kell csinálnom , hogy helyesen jelenjenek meg a betük , nem mind teljessen magyar:notworthy:
encoding.rar-t felraktam müxik
or HEX format
Ezt megcsinálod hibbátlan lesz. Ott a file feljebb. Ha kijon egy frissites, ujra be kell masolni az encode filet.
