Hungarian Thread
hi csaba from hungarian (Komló)
segitsetek .vettem egy vu+ uno t dvb c tunerral digi kabelhez hogyan es mivel tudom megoldani a kodolt csatornak vételét?
help me. I bought a vu + uno dvb c tuner for digi cable how and how can i solve the coded channels?
Hi Csaba,
Put a CI modul in the VU+ Uno with a Digi Card.
Tibii
Hi All,
Please find a new LameDB database for DreamSet editor
including new UPC Direct Hungarian channels.
Please also find an updated Picon set for UPC Direct
Hungary. If something is missing, just let me know.
Tibii
Hi All,
There is a new version of EPG translator that I found on the Web.
How to Use it:
1) Extract the RAR file and copy the 'enigma2-plugin-epg-language_1.08_all.ipk' file to the VU+'s 'tmp' directory.
2) Press 'menu' on your remote then select > 'Addons' > 'Manually install Ipk packages'
3) Select the package 'enigma2-plugin-epg-language_1.08_all' and install it.
4) Restart VU+.
5) Press 'menu' on your remote then select > 'Setup' > 'System' > 'EPG Language and cache' (last item, scroll down)
6) When the plugin is launched > 'Enable EPG language - Yes' then 'Enable autostart - Yes' then 'EPG language - Hungarian'
Good Luck!
Tibii
Hi All,
Here is a new encoding.conf with updated transponder list to
show Hungarian characters right for UPC Direct in EPGs.
Just copy it into usr/share/enigma2
Tibii
Hi All,
Please find a new UPC Direct FAV database for DreamSet editor
Tibii
Hi all! Help me please!
I have a vu+Solo4K.I want to transfer files my pc to stb,but I couldnat. FileZilla and DreamboxEdit do nat make connektion.I set ftp://root@192....,root,rootpw,port21.When used first time the BlackHole 3.0.1.F it worked correctly.
Hi Tibi!
New to VU+ with a Duo 4K with latest VTi. Have Digi - do you have a picon set for Digi? Can I use the Upc one?
Also: some of the Hungarian accented chars (e.g. ő) don't show up on the TV (they are ofc OK in OpenWebif) - how can I fix that?
Thx for any help,
pi
Hi Tibi!
Thx for any help,
pi
Hi Pi,
I use Blackhole on my VU+ and I don't know much about VTI. I guess you can use the Digi images, they are just
simple pictures, but I don't know how to load them in VTI. If any channel image is missing that you need just
send me the channel names over and I quickly make the picons for you.
About the characters, in Blackhole there is an encoding.conf file (probably it exist in VTI as well). This has to be changed
for the characters to show ő, ű properly. You can download it from my previous uploads. In case of EPG you could also
use an extension called: enigma2-plugin-epg-language. I uploaded one version earlier, just Google it for the
newest version.
Any questions, just let me know.
Best Regards,
Tibii
Hi Everyone,
Here is a new UPC Direct FAV list with updated channels that you can upload
with editors like, DreamSet editor.
I also attached a new encoding.conf, just upload it to /usr/share/enigma2
and replace the encoding.conf file. It fixes ő, ű issues.
Best Regards,
Tibii
NEW UPC HUNGARY PICONS AND CHANNELS,
Here is a new UPC Direct FAV list with updated channels (I renamed some channels) that you
can upload with editors like, DreamSet, E-Channelizer editors.
Also find an updated set of picons.
Tibii
Szia Tibii.Tudnál segiteni ezzel az encoding.conf file-al kapcsolatban.Digi csatornák epg szöveg megjelenitése egy kicsit bugos(ékezetes betűket nem jeleníti meg).Válaszod előre is köszönöm!
Szia Amfiton, Nem voltam itt egy ideje és csak most láttam, a kérést. Kiegészítettem az encoding.conf-ot a Digi csatornákkal. Próbáld meg most. Tibii
Hi Everyone,
Here is a new UPC Direct 2021 FAV list. Removed Discovery and related channels and
included the new ones like: Love Nature, Travel XP HD, etc. You can upload it with
editors, like DreamSet editor.
I also updated the encoding.conf file to get the Hungarian characters right.
Best Regards,
Tibii
