IPTV Channel Updater
@nokia3310,
Thanks for links ;)
If you can't add files, take Filezilla, this app is more powerful than DCC and more simpler than Telnet...
thanks for your reply only just got round to do some reading Christmas and all that. getting back to these files i don't use dcc i use fsahfxp.but i wii try filezill. report back.
Update: 11/01/2014
Good morning, here released a fixed IPK. In order for the plugin with the links of HasBahCa should work again clean. 1.30-10.01.14 The plugin should be displayed, otherwise you have not the latest version!
Thx @ HasBahCa
1.install plugin from green panel
2.go to plugins menu , run plugin
3.select from who country channels are you want to have
4.restart enigma after finish ichannels update
5.found your channels in bouquets last entry
ok..........if I install comes error matter what I do is always error
mmmm my englich is not good excused
was kann nann den machen das kann ja nicht so schwer sein oder
I can not install enigma2-plugin-extensions-iptvlistupdater_1.31.%2Bgit548%2B65e5ba2-r13_mips32el.ipk
why the error come
