IPTV Channel Updater
It works fine now. I thought the two 'libary' may be included into the plugin. I was wrong. after installed the two "libary files", everything is fine.
hi
i have this error when i install
root@bm750:/var/volatile/tmp# opkg install librtmp1_2.4.ipk
Installing librtmp1 (2.4+git490+a9f353c-r3) to root...
Configuring librtmp1.
Collected errors:
* pkg_run_script: package "librtmp1" postinst script returned status 1.
* opkg_configure: librtmp1.postinst returned 1.
what can i do ?
I also with Black Hole Vu+ Duo 2.0.9
I have the same problem you do not install the plugin
(installed before the two libary files (librtmp1-2.4, udpxy-ver0.23))......
I am not very clear what is exactly means you said in your post. My VU+ Duo2 BH2.0.9 does not show any installation problem when I unpdated (install) the IPTVlistupdator plugin. No erro is reported and I have checked a few links, they works. You know the nature of those links, some of them certauinly do not work.
IPTV List Updater
Changelog:
from 16.03.2014:
- add first Streams for Livestreamer (Thx @mydebian)
from 09.03.2014:
- fix Converter: Russia SibirTelecom
from 08.03.2014:
- add Bouquet: English Vietnam Movies
from 27.02.2014:
- add new language-file: hungary (Thx @pisti)
Thx to Nobody28 and all involved
hi can anyone help I have a vu+solo2 using blackhole 209.1
I have down loaded all of the above 5 files, ftp to temp, reboot stb and still no iptv?
no iptv plugin.
where am I going wrong?
...and where and how do you install these 2 library files please? I'm stuck...
Any chance of a dummy guide to installing this updater please? A guide that is simpler, step by step and with all the files needed. The more I read the more I get confused. I installed the iptv updater but it does not show on Solo2 receiver. Please help, somebody !!
