IPTV Channel Updater
Yazz,this is how I installed mine and it works.First,file transfer librtmp1 2.4 to temp folder in your box.I use Flash FXP.Then go to Menu/Addons/Manually install BH packages and install.Then restart enigma2.Secondly,file transfer udpxy 0.23 to temp folder in your box.Then again go to Menu/Addons/Manuall install BH packages and install.Restart Enigma2.Thirdly,file transfer iptvlist updater to temp folder in your box.Then go to Menu/Addons/Manually install BH packages and install.Restart Enigma 2 and Bingo!The plugin should show in your plugins.
1.librtmp1 2.4
2.udpxy 0.23
3.iptvlistupdater 1.40
By the way,thanks to everyone that has helped educate me over the past 5 months and made my Solo2 experience a much better one.Cheers!!
I tried step by step as suggested by "Robocop1967" but the plugin is not installed, my setup is vu duo with black hole 2.09.1
Update: 12/04/2014
Changelog:
from 10.04.2014:
- don't install adult channels with install all (yellow button)Thx Black64
- remove Button: Downloadlist (not needed!!) Thx Black64
- change Version to 1.52
Thx to Nobody28 and all involved
Update: 12/04/2014
Hi can anyone pass this website on to the developers
http://tvtoss.com
might be able to use the streams to add to there iptv lists like there was on the usa streams.
Mod edit: No Live Links, Please!
hello very good this app but why remove uk movies section is more 1000 movies and good quality pls add next update again
http://tvtoss.com
Sorry admin.
Sent from my GT-I9300 using Tapatalk
I have an issue in My device Vu solo2.
when i try to install a list to add into the tv Bouquet by using IPTV List Updater V1.10 unfortunately, the channels don't exist! idk why?
before a year it did work very well.
I just want to add USA channel to my bouquet like TNT, abc and nba.
Thx
IPTV List Updater
11/05/2014
Changelog:
from 10.05.2014:
- fix Teledunet ID0 Update (Thx testi)
from 09.05.2014:
- fix Depend: librtmp1
- change Version to 1.61
I have tried to install the IPTVlist updater Ver 1.61, but it always looking for some things from lib and server, I did not cach the error messaage exactly, I use BH 2.10. Please offer any help. Do I have to install the liverstreamer1.8 before the installation?
hello have you read all the post from the this page ? the first one #post-132852
