IPTV Channel Updater
hello have you read all the post from the this page ? the first one #post-132852
Thank you very much for your reply. I did read all posts on this title, but may missing something. The two lib files are also installed. But the error is still there.
mysat-bs... Hi, Do you mean to replace all the files on the plugin's folders mannually?
Along the way usr / lib / enigma2 / python / Plugins / Extensions / IPTV-List-Updater
replace old IPTV-List-Updater to the new IPTV-List-Updater on overload and everything will be ok
Thanks @alex622. I have done it, it works ( I only tried a few links)
Does anyone know why im getting /var/lib/opkg/info/librtmp1.postinst refusing update also now its stoping me installing other plugins tried about 4 times had to flash it to install anything
how to create iptv bouquet in list channel ,i have the folder stream.xml in my plugin stream tv,image blackhole vu+ solo...thanks
Can you explain me step by step what should i do to install this plugin?
thanks
fabrizio
Sorry,I'm not at my computer but use the instructions in post 161 with the first two files and the latest IPTV updater file in post 171
