JediMakerXtream IPTV Bouquet plugin
Hello,
I want to use this plugin for the first time. I have VU+ Uno 4K with VTI-14.0.5 and Atile HD skin.
In the first post I don't know what to do with this:
"2. Open playlists.txt and add your providers from script file."
Which playlists.txt ist meant here? (My internet provider is Telefonica o2 Germany)
Can anyone help me please?
Best regards
Panther-6
Though, ask them ( VTI and your PROVIDER ) how to do it, but read first our board rules --> https://www.vuplus-community.net/rules.html, because it seems you haven´t read it, in the moment you joned our community.
Note: Sanity, patiente, education ... might be present allways ... more: This is BlackHole board ( where we have 2 images ( BlackHole and Open BlackHole )), you are asking for support, reagrding a thirdparty image ( VTI ).
So, you are :offtopic:
Hello,
I have installed this plugin and I am very happy with it.
Only thing I can't figure out it how to pin protect a sub bouquet ;)
and changing channel doesn't work for me.
I have BH image on UNO 4K box. using left /right key or ch-/ch+ key don't work, i have to use up key, then move to the channel i want and press ok?
Thanks for your help in advance
JEDI MAKER XTREAM - Version 5.27 (Universal)
-Plugin now picks up 2 different types of older xtream panels.
-Categories can now be selected for older xtream panels. Also you can now view the channel list for older panels.
-Removed the check for empty categories. It was causing issues with some older panels, slows creation down and wasn't bringing much to the party.
-Removed Rytec UK downloading every run. This was some experimental code I must have been messing with. The main code was commented out anyway, so it wasn't doing much other than slowing creation down.
-Improved local and external M3U playlists handling.
-Fixed buffer option description not showing in bouquet settings.
Hello, I have an Open Blackhole image, my channels are using prefix of country, then it freez after 60 seconds, tried both open and default blackhole images, nothing change, with Jedi maker plugin extension I believe as mentioned it will solve the issue, the only problem here that (IT DOESNT FIX) I am thinking now to add this FHD skin, but in the list it is not available (OBH skins) is this skin mandatory, and why is not listed in repository skins, should I mpve to the Normal Blackhole image to find this skin. how can I do it? Many thanks in advance
Hi guys
I have a problem here with OBH which is black screen with sound only. Actually this happens when I switch to 4k channels or movies in IPTV
Anyone face this issue?
Thanks
JEDI MAKER XTREAM - Version 5.29 (Universal)
-Minor update.
-Prevented Auto update deleting bouquets without first checking providers server is online.
-Amended Catch up code, so if a channel states its has catchup, but there is no times and dates data to display, user can now manually pick from hourly times.
Dear all,
Yesterday I have tried the plugin for the first time. The plugin works very well but my question is: how to record and IPTV channel?
If I try to record I can start the recording and after stop it but, if I look on my default path for recordings "HDD/movie", I don't find any records.
Many thanks in advance for your help.
Bye
Roberto (alias don_hidalgo26)
Only 1 connection.
I've used for long time "Xcplugin by Lululla" to record iptv live stream or download iptv VOD but the problem is that, while you record with xcplugin, you cannot change the channel going to view, for istance, another DDT channel or SAT channel like you can do when you have more tuners...
So my question is if there is a native function in OBH to record iptv streams and how can be done.
