JediMakerXtream IPTV Bouquet plugin
JEDI MAKER XTREAM - Version 6.11 (Universal)
Removed the troublesome place bouquets at top option that is playing havoc with peoples bouquets.
Autobouetmaker. Delete ABM bouquets.
JediMakerXstream - Delete All Jedi IPTV Bouquets
Do a full reboot
Do an ABM scan
Recreate your Jedi Bouquets.
JEDI MAKER XTREAM - Version 6.12 (Universal)
● Fixed slow server reponses that prevented series channels being populated (set timeout to 10 seconds - that should be plenty)
● Fixed url output type picking up any # alias at the end of the line, therefore defaulting to wrong output type.
KiddaC wrote:
I have put the timeout value on
downloads.py
def checkGZIP(url):
response = None
request = Request(url, headers=hdr)
try:
response = urlopen(request, timeout=10)
JEDI MAKER XTREAM - Version 6.14 (Universal)
-Reversed catchup lists.
-Removed code for legacy panel.php panels. (I am pretty sure no one is using this anymore - only put in when the original xtream codes went down)
-Added in the 8193 option for dreamboxes.
-Bouquet name can now be defined in the playlists.txt file like xstreamity by adding # name to the end of the line
This not a plugin for Play services like svtplay. This is a plugin to create bouquest from IPTV.
Official svt app is only avalible for Android like Viaplay and Netflix.
Vu+ has no support for those but you can try and install Kodi and from there install svtplay but it's very complicated and you only can stream in SD
If you have smart tv install the app on your tv instead
