just got my Vu+Duo2 today and having difficulties ... HELP!
Walk away from it for an hour and then try again.
Have a cup of tea ( or something stronger ) or it will drive you crazy.
its obviously very frustrating, not only because its not working properly but also for the fact that i had been waiting for it for almost a year now :D
have only one other usb 3.0 64gb ... that one doest format into FAT32.
but this usb FAT32 that i have, i used/using for various other receivers without having an issue.
should i factory reset the box?
That says nothing
if it your USB stick does not work with your box.
Find a cheap USB stick 1-4 GB
and it will certainly go.
We all understand as we have all been where you are, trust me with a little time you will enjoy it but for now take a breather and we are always here to help when you are ready.
Don't give up. ;)
Hi mate I tried 3 different usb sticks before I managed to download image. I like you was ready to throw box out the window. But trust me once your off and running you will love the vu box. Ps do lots of research and reading. Best of luck and keep the head ozzy
Now most out some exotic USB sticks
so this is a problem.
Use old cheap USB stick and it goes out first.
found the configuration for the 16 LNB (Diq 1.1):
http://www.satellites.co.uk/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=48182
Transcend 64GB USB 3.0 wont format into FAT32, not by the HP Tool either.
SanDisk 32GB is formated FAT32, will try out soon ... atm scanning 16 LNBs :D
