Latest Mediaportal
High,
i got a greenscreen in 7.7.4 using movie4k.
Something wrong with Skin in line........
The other Options seem to work properly.
Greetings
Slaroni
High,
Greetings
Slaroni
HELP REQUIRED
I was very happy using VU+ Zero but recently in last week of Dec 2016 I updated the Openpli which was previously running smoothly, in a couple of days I got a msg on screen that my version of Openpli is not good so better to update on previous version by USB, which I didn't, in few days my receiver as well as Tv got stuck up, I have given the Tv to Samsung Repair Shop but don't have any support of VU+ Zero in my country.
Receiver is hanged up, don't take Original firmware USB to update neither Opnepli firmware upgrade and same is if I tried to only upgrade with the new Bootlooder from VU+ Zero site.
Receiver is hanged up and Ethernet plugin light are constantly ON at receiver back
I couldn't get any help from Openpli fourm.
Please suggest what should I do to get it ON again
HELP REQUIRED
Please don't cross posting: http://www.vuplus-community.net/boa...-zero-dou2-higher-symbol-problem.27945/page-4
And here you are OT because Trd talk about Mediaportal and this is BH image forum.
Good morning, can you tell me why the mediaportal update fails to fruition? I attach log file that shows the error. Thanks for any suggestions
File Log:
Downloading http://feeds.vuplus-community.net/3rd-party-settings/Packages.gz.
Inflating http://feeds.vuplus-community.net/3rd-party-settings/Packages.gz.
Updated list of available packages in /var/lib/opkg/official-3rd-party-settings.
Downloading http://feeds.vuplus-community.net/3.0.2/vuduo2/all/Packages.gz.
Inflating http://feeds.vuplus-community.net/3.0.2/vuduo2/all/Packages.gz.
Updated list of available packages in /var/lib/opkg/official-all.
Downloading http://feeds.vuplus-community.net/3.0.2/vuduo2/mips32el/Packages.gz.
Inflating http://feeds.vuplus-community.net/3.0.2/vuduo2/mips32el/Packages.gz.
Updated list of available packages in /var/lib/opkg/official-mips32el.
Downloading http://feeds.vuplus-community.net/3.0.2/vuduo2/vuduo2/Packages.gz.
Inflating http://feeds.vuplus-community.net/3.0.2/vuduo2/vuduo2/Packages.gz.
Updated list of available packages in /var/lib/opkg/official-vuduo2.
Downloading http://netix.dl.sourceforge.net/project/e2-mediaportal/enigma2-plugin-extensions-mediaportal_8.0.2_all.ipk.
Upgrading enigma2-plugin-extensions-mediaportal from 8.0.1 to 8.0.2 on root.
Checking for an older version of MediaPortal in the system...
An older version of MediaPortal was found
Checking free space...
Proceeding to installation...
*  MediaPortal installed                               *
*  Restart the Engima2 GUI to activate the plugin      *
Configuring enigma2-plugin-extensions-mediaportal.
Downloading http://netcologne.dl.sourceforge.net/project/e2-mediaportal/enigma2-plugin-extensions-mediaportal_8.0.2_all.ipk.
Installing enigma2-plugin-extensions-mediaportal (8.0.2) on root.
Downloading http://netcologne.dl.sourceforge.net/project/e2-mediaportal/enigma2-plugin-extensions-mediaportal_8.0.3_all.ipk.
Collected errors:
* opkg_download: Failed to download http://netcologne.dl.sourceforge.net/project/e2-mediaportal/enigma2-plugin-extensions-mediaportal_8.0.3_all.ipk, wget returned 1.
Thanks
Thanks
Next time .... even when posting logs, make sure to not post live external links, as you did.
By the way, the server ( address or file ) where you trying to download, doesn´t exist or refused your request. This has nothing to do with Black Hole or Open Black Hole image, but with license use requirements, since version 8.0.0, that you can read from the git.
So there´s no issues with Black Hole or Open Black Hole image.
thanks,
