Latest Mediaportal
Hi
No thats what you post is the MediaPortal for DreamOS 2.5
Python-pyexecjs and the nodejs are needed for example
Diverse Fehlerbehebung
Neu: HDZog
VJAV
Thx an das Team
Unfortunately i could not find such a Site for VU Boxes
Hi
External live links are not allowed in our board.
The link you have posted are for dreambox Os OE 2.5 not for mipsel32 or Armv7 Vu+ STB´S.
Mediaportal has a license as OpenSource and not a freeware after version 8.0:
https://github.com/dhwz/e2-mediaportal/blob/gh-pages/version.txt
The links were removed because they are live links and they are not for VU+ architecture.
Hi
You have seen that i Post hxxp and wxw instead of http and www if
that was not enough ? sorry for that
sure that files are for DreamOs as i wrote too the "links" are
posted as an example how the Files named
Edit:
And no your "link" is not a solution
2nd Edit:
also your 2nd "link" helps not
Hi
It doesn't matter ... it was an external live link also ... here is a test that you can doi:
--> hxxp://wxw.vuplus-community.net/board/threads/latest-mediaportal.12215/page-20#post-234359
Verify it by yourself!
thanks,
Note: We don´t need files, plugins, skins, etc for "dreamos", sorry.
Hi
No Problem for me but you also did not Update the VU Plugins
so they did not Work as they should
If you are in the situation to update Kodi in BH than we don´t need
to Talk about other Plugins which are much better supported as the VU Plugins
Hi
Me again to correct possible miss understandings
I´m not looking for any Dream Plugin here in this Board
what i´m looking for are :
additional packages for the MediaPortal,some others called it also additional dependencies,
so that the MediaPortal runs correctly with all new plugins like:
Neu:
HDZog
VJAV
and a few others.
Hope you now understand what i´m asking for ;)
Edit:
Be sure that i know were to Find OE2.5 Plugins :cool:
Hi
Neu:
HDZog
VJAV
and a few others.
Edit:
Ok. I´m sure of all, although don´t think is so simple.
1) Is a matter of a sillly license, in my own opinion, that not makes sense.
--- > https://github.com/dhwz/e2-mediaportal/blob/gh-pages/LICENSE
2) I know that you understand that .deb plugins are for dreamOS, but other users don´t!
3) Is not only the 2 packages you pointed on your post ( it needs Python-pyexecjs and the nodejs ) but it needs also the dependencies of nodejs:
  • libc6 (>= 2.24)
  • libcrypto1.0.0 (>= 1.0.2j)
  • libgcc1 (>= 6.3.0)
  • libssl1.0.0 (>= 1.0.2j)
  • libstdc++6 (>= 6.3.0)
  • libz1 (>= 1.2.8)
If you list by telnet to enquiry if the "libraries" files are present on the feeds or embedded in image ... you´ll see that rev version is under then the one needed, and can break the dependencies needed, if you change them.
4) We can´t prejudice a stable image based on the official image.
5) You can allways use Open BlackHole image that has all the files needed to install and run properly.
For Latest Mediaportal ARM processors VU+ Black Hole (tested ultimo 4K BH image)
Support
HDZog
VJAV
and a few others.
Install python-pyexecjs-node_1.4.0-r0-6.11.2_all.ipk
(copy file to /tmp , green button>>Yellow button>>Manually Install Ipk packages)
Install latest Mediaportal
Neues Update auf v9 0.6 online verfügbar
Ab der version 9.0.5 ist die grauzone nicht mehr sehen.
die muss dann im menü folgendermaßen aktiviert werden:
1. im menü ganz nach unten scrollen
2. user-erweiterungen aktivieren => JA
this grauzone activation option does not show for me.Should menu language be german or what is wrong? Last thing in the menu is options for debug.
