Latest Mediaportal
this grauzone activation option does not show for me.Should menu language be german or what is wrong? Last thing in the menu is options for debug.
1.
you need for this extra plugin for grauzone search www net
enigma2-plugin-extensions-mpgz
install ipk file
2.at the end of the menu in Mediaportal
Activate User-additions
3. Configure after that in Menu what you want to see.
For that grauzone plugin there is also files with .deb ending. what for are those .deb files ? difference between those and .ipk file?
deb ist aber nicht für die vu+ !
ivch stell dir trotzdem mal eine rein
File removed as it is not supported by VU+ STB
Es gibt ein neues update wieder , leider crasht mein Receiver beim online update.
Habe nun die ipk datei installiert das gleiche Ergebniss.
Habe dann danach die grauzone neuinstalliert und nun funktioniert Mediaportal wieder.
welche box hast du? bei mir funktionert es nicht auf solo2
Older versions of mediaportal had different kind of skins.This new one has only default skin,where have all skins gone? Not a big problem,but used to version that showed version number on top and shows things little bit different.Don't remember name of that skin,but game with mediaportal.
When mpgz plunging autoupate message showing in the screen after installing mediaportal I click yes to update then I have crash evrytime I tried .. Any solution ?
