Latest Mediaportal
What are these two files? what will these do if installed?
Same as old files, if you use Black Hole image
and installed old files.
The difference is that these are much smaller and compiled for the image.
These files allow you to see some add-ons that you normally can not play.
About , Javhd and Javbraze not working
this is a website certificate problem.
Those who have no support in the Black Hole image.
The question is whether these sites are safe.
I do not know that.
Hello,
thanks for blackhole 3.0.8 image.
media portal ddl.me kinox unfortunately, it does not work. everything works with open BH. Vu Solo 4 K.
How can I solve the problem. Thank you
Hello,
You can use E2iPlayer (IPTV player for ddl.me)
Mediaportal use twisted web to parse ssl website (ddl.me)
It does not have support in the VU + based image / Black Hole image
Open Black Hole image uses different twisted web coding.
Can it be fixed in Black Hole image?
Javbraze not working.Shows page numbers in different categories,but not showing movies. Is this about Mediaportal or Javbraze webpage?
