Latest Mediaportal
It detects the new version and start upgrading with no apparent errors but after restart you still have the old version.
Downloading http://feeds.vuplus-community.net/3rd-party-settings/Packages.gz.
Inflating http://feeds.vuplus-community.net/3rd-party-settings/Packages.gz.
Updated list of available packages in /var/lib/opkg/official-3rd-party-settings.
Downloading http://feeds.vuplus-community.net/3.0.9/vusolo2/all/Packages.gz.
Inflating http://feeds.vuplus-community.net/3.0.9/vusolo2/all/Packages.gz.
Updated list of available packages in /var/lib/opkg/official-all.
Downloading http://feeds.vuplus-community.net/3.0.9/vusolo2/mips32el/Packages.gz.
Inflating http://feeds.vuplus-community.net/3.0.9/vusolo2/mips32el/Packages.gz.
Updated list of available packages in /var/lib/opkg/official-mips32el.
Downloading http://feeds.vuplus-community.net/3.0.9/vusolo2/vusolo2/Packages.gz.
Inflating http://feeds.vuplus-community.net/3.0.9/vusolo2/vusolo2/Packages.gz.
Updated list of available packages in /var/lib/opkg/official-vusolo2.
Downloading http://master.dl.sourceforge.net/pr...enigma2-plugin-extensions-mediaportal_all.ipk.
Upgrading enigma2-plugin-extensions-mediaportal from 2019051201 to 2019090701 on root.
Problem solved
it is all about python requests
I used to use the telnet command
opkg install python-requests
which downloads python-requests 2.9 which is a bit old for the new MP versions
I installed manually python requests 2.12 and then allowed MP to do the automatic update.
Now I have the latest MP version.
Thanks guys
Javhd shows films on list,but films does not start. Shows text "not supported stream hoster,try another one". Is it something wrong with mediaportal or javhd website?
I have VU + UNO 4 to SE and Black Hole 3.0.9.
I can't get Mediaportal up. I have an old Mediaportal plugin removed by what telnet command. Then I have to install python requests 2.12.4 first, python pyexecjs 1.4.0.r0 armv 7ahf or plugin-extensions mpgs all ??? Who?? And finally install a new version of Mediaportal from September 7, 2019 ??
Please, give me an advice.
Now it is OK. The first opkg install python 2.12.4 by Telnet and install it again in VU+ and Mediaportal works OK after update.
Hi there,
with last update (all ok) but the videos do not start, I click on the file video and MP show me the infobar just 1 second, then disappears and not
reproduces. I have vu+ duo2 and OBH 4.2. Any idea, I am going crazy.
Please help me
Possible to fix Javhd and Javbraze?. Javhd shows this if you try open any movie "no supported stream hoster,try another one" and Javbraze freezes mediaportal.Shows directories,but if you try enter one mediaportal freezes.
Hi there,
I'have the same problem of gandalf63 ...with last update the videos do not start, I click on the file video and MP show me the infobar just 1 second, then disappears and not
reproduces. I have VU+Solo4k and last BH .
has anyone any suggestions?
