Latest Mediaportal
I still have the same problem even after the last update, the streaming don't start. Can someone help me?
HI,
I had the same problem in my Vu+solo 4k and I solved with the telnet command that I found two week ago:
telnet :
opkg update;opkg install ffmpeg
opkg install exteplayer3
If you want you can try so.
Bye
Delfino
Should this still automatic update from previous version? Does not show anything for update. Check updates is yes.
