Latest Mediaportal
Last MP uses newer python files that we don't have
in VU + coding
ONLY for 4K VU+ box
To install the latest version you must first manually install all python ipk files from my ZIP.
(copy ipk files to /tmp and Install manually green button>>yellow>>Manually Install ipk packages)
Note
you must install last
python-requests_2.22.0-r03_armv7ahf-vfp-neon.ipk
You can now install the last MP
Note
As far as I've seen there are MP addons that don't work.
I am not the author of the MP so you have to ask the author.
For YouTube you need an Api-key
If you need it you have to look on the internet how to do it
API key for You Tube and then you have to add it to the MP.
hi and thx for you help,
same problem here on duo2 witch python is needed for the update
Hello. I`m just a newbie at Blackhole and Enigma2. I cant instal this plugin and collect some errors^
Collected errors:
* satisfy_dependencies_for: Cannot satisfy the following dependencies for enigma2-plugin-extensions-mediaportal:
* python-youtube-dl (>= 2020.06.16) * python-requests (>= 2.11.1) *
Where i can find missed dependencies for my image? Thanx in advice
My receiver is VU+ZERO4K with BH 3.0.9.L image
Collected errors:
Try this package ... for sure it will not work for all data, but will install and severall ones will work.
*** ONLY FOR BLACKHOLE IMAGE ***
Last MP Mediaportal E2 Plugin 17.07.2020 uses newer python files that we don't have
in VU + coding
ONLY for 4K VU+ box
Note
Note
I have to say I haven’t tested YouTube
it becomes complicated and a little boring these changes every month.
Mouna , did you find python update file for vu+ duo2? I have searched also,but did not find.
Have you tried this file from @nunigaia
it's the same file but without youTube and with older python-requests
I did not notice any effect on the work with duo4K
of course I didn't test everything and i have not test with duo2
Unfortunately the author of this plugin has stopped giving
good support for this plugin so some things don't work.
Not because of the python files but because of the plugin.
Mediaportal works, but does not update. Somehow i got the previous version working,when it came out. Now it says can not update ,because it is same version. Mediaportal shows version 31.5.2020. Mediaportal is good plugin, so it is sad if the support is gone.
That is the old version, it has just been updated
youtube-dl
but YouTube doesn’t work, at least not with me.
He continued to work for DreamOS at least for now.
Update
Mediaportal GrayZone Plugin 13.09.2020
Hall9000 ;)
to @: matrix10 and @ Hall9000- I installed MP python and media portal from 17.7.2020 and I'm satisfied. I have VU + Uno 4K SE and IMG Black Hole.
I don't know why there is a MediaportalGray Zone Plugin from 9/13/2020, because I can't install it in my receiver. Thank you for answer.
MediaportalGray Zone is not Plugin
It is an add-on to Mediaportal Plugin
This is not a separate plugin.
And it is installed after the Mediaportal installation.
Other information on the use of Mediportal search on the Internet.
Again Basic information.
1. Install Mediaportal
(It uses the file from @nunigaia post 607 best because it does not change the structure of python files in the BH image)
2. Install the Gray Zone post 613 ( @hall9000 )
How to configure.
1. Launch Mediaportal
2. Press the Menu button
3. Setup Mediaportal
For the gray zone Setup Adult PIn
OK save setup
Now with the Epg button you can use the gray zone
In the Gray zone
With the Menu button you can make a setup again
(links in the Gray Zone) with OK button save Setup
with the blue button you can select other entries
