Latest Mediaportal
Hello everyone,
since last night series stream does not work. error message please wait. Nevertheless I gave an email address. how are you all doing ?
thank you
Hello everyone who has login problems with the s.to plugin.
Solution: 1. Install the file commander plugin from feed or via FTP on the PC
2. Path urs \ lib \ python \ plugins \ extensions \ mediaportal \ additions \ useradditions \ serienstream.py
3. then display or edit 2 scripts (Python)
4. Rename at 0007 Base_Url s.to to serienstream.sx
5. Restart
6. Done
Have fun
PS. Watchlist must be saved again.
health of the creator
Why don't you write a path properly?
No spaces, please and no manual writing, and the right slash ("/") because, as in this case, you may easily make mistakes (urs instead of usr).
Why on earth you don't simply copy a path from your FTP client or terminal session? It's not a crime to paste a local path! Is not an external URL!
I'm not talking just of this plugin but in general, when a local path is provided in a forum's post.
Thanks.
unfortunately I didn't notice it ..
usr \ lib \ python \ plugins \ extensions \ mediaportal \ additions \ useradditions \ serienstream.py
Thanks
usr / lib / enigma2 / python / plugins / extensions / mediaportal / additions / useradditions / serienstream.py
Again... this is not a path! You can't copy and paste it in the FTP client!
This one is a real path, useful for everyone, without the useless spaces:
usr/lib/enigma2/python/plugins/extensions/mediaportal/additions/useradditions/serienstream.py
Last MP uses newer python files that we don't have
in VU + coding
ONLY for 4K VU+ box
To install the latest version you must first manually install all python ipk files from my ZIP.
(copy ipk files to /tmp and Install manually green button>>yellow>>Manually Install ipk packages)
Note
you must install last
python-requests_2.22.0-r03_armv7ahf-vfp-neon.ipk
You can now install the last MP
Note
As far as I've seen there are MP addons that don't work.
I am not the author of the MP so you have to ask the author.
For YouTube you need an Api-key
If you need it you have to look on the internet how to do it
API key for You Tube and then you have to add it to the MP.
