Latest Mediaportal
Any other has problem with media portal and BH OE3.0. I cant install it, I got it can't not dependences : gst-plugins.good-flv ;gst-plugins-bad-rtmp; gst-plugins-bad-fragmented. On BH 2.7 works ok. I tried opkg update bat no improve. What I need to do now?
acer2
acer2
I several times tried to install mediaportal 7.31 on my box (Vu Solo+) but it seems with 3.01 it doesn' work. The installation freeze the box and every time I have to manual reset the Box .. It seems that BH 3.0.1 on VU+ Solo leave not enough memory for the plugin. I came back to B.H 2.17 and with mediaportal 7.31 OK.
Delfino
version 7.3.2 needs python-argparse
then via telnet
opkg install python-argparse
Box network stopped to work even when everything is set correct, any idea ?
nach installation dieser datei opkg install python-argparse und update mediaportal 7.3.3 opkg install python-argparse
fduntioniert das plugin bei mir
This breaks your net connection.
after you install argparse you can even connect and install BH plugins.
It somehow blocks every ingoing connecition on the box.
Last good media senter is 7.3.1
Sorry to hear that but no such problems for me after installing it.
well when installing media portal on a bran new flashed image , my case 3.0.1.
I see when i install mediasenter via plugin menu, when done installing it throws several errors, but goes so fast i can see what it is missing.But looks like several python packages.
When i then open plugin (green button it says argparse missing) then when installing that leads to no outgoing connections.
So wich packages are the mediasenter needing, its is more than just argparse.
hi why when i installed mediaportal 7.3.4 on solo se v2 i can't activate por** so please how i activate this plugin thanks i have blackhole 3.0.1. thanks
