Latest Mediaportal
to install version 7.1.5?
it doesn't help
Uninstall first previous Mediaportal versions ... and reboot your STB!
Upon reboot ... install latest Mediaportal plugin.
By the way, what skin are you using ... on your STB?
See too, if you have any crashlog on your /media/hdd root!
Best regards
Mx_graphite caused the issue. Reinstalled and fixed. Thank you so much!
@Matrix
How can I use this skin in mediaportal?
Install it from the addons feeds!
On your remote control press:
<GREEN> <YELLOW> <ADDONS DOWNLOAD MANAGER> <BLACK HOLE IMAGE SKINS>
I know how to install the skin. :-) this one is not available for mediaportal, but it doesn't matter. I resolved my problem with ui set up. Thanks
i have vu+solo 2 with bh 2.13 image.till 2 days ago workt youtube tv plugin perfect.since then everytime i try to watch video on youtube tv first load the video then comes a log on screen : an error ocured.please try again later.can someone help me .thanks.
