Linux commands for your Vu+ (for Dummies)
The important is that you solved but, please, notice that "your" guide tells exactly the same things that ours does.
As a matter of fact, also your guide says you have to decompress (that means unzipping) the installation file. Afterwards, you must copy the vuplus folder to the USB flash drive... ;)
I'm sorry, but that was exactly wath i did .... before you gave me your splendid trick! And it seems that it did'nt work. I'will try again to check that.:)
Turn off the receiver behind the receiver, insert the usb stick, and then restart the receiver from the back switch. After reflashing, stop the receiver swich, remove the stick and reboot it.
Hi Sara
I think think this is a good place to get some cheap licenses from , but im not sure if they are orinal or not:
xxxxxxx
Envoyé de mon SM-J810F en utilisant Tapatalk
**** WARNING ****
This is a satellite board for supporting Vuplus original STB´s regarding BlackHole and Open BlackHole images.
External live links are not allowed on our board.
Read our board rules --> https://www.vuplus-community.net/rules.html
