MX HD HiColor(True 32 bits + alpha)
Since is under construction
can i ask if it will work with uno 179( i read somwhere that 179 support to 32 bits png)
anyway great work
Thanks Matrix 10
I think not for all panels,
Menu and panels look very good.
It seems that we will again have at least two versions
with different channel list and EPG list,
because opinion is divided as I expected.
I have some local colleagues who also give their opinions
The panels look good.
Around the lists SAT/EPG are divided opinions.
Absolutely better for channel list panel is option 2.
But maybe You think that with this option fall down Your new concept of skin(panels). No It is not !
I think You can very well combinate this channel list which like much users with all other panels which have design like You envisioned. It is excellent option.
no no
We have two concepts
One began with Elegance HD
and the other with MX HD.
So we have two parallel skin lines with their differences
and similarities.
MX HC1 & MX HC2
First skins in HI COLOR
You can download from our image server.
These skins are made on VU + Solo2
where a show all its power and quality.
Of course is possible to use them in other boxes
but not with the same speed.
MX HC2 version is lighter and faster.
(no background buttons)
Warning for those who continue to publish and modify my work,
without my permission.
Skin graphics are protected with copiright.
And the skin can only be used modified and published with my permission
excluding VU + Black Hole images.
MX HC1 skin
Category: Graphic
MCN: CGW0Y-X7N0S-02K8Z
© copyright 2012-12-25 09:27:54 - All Rights Reserved
MX HC2 skin
Category: Graphic
MCN: C2GYH-ESCX1-7TN64
© copyright 2012-12-25 09:29:19 - All Rights Reserved
Tested both on Ultimo and work .
HC1 is fine , HC2 is slow and it has nothing to do with the skin but
the box's power.
Thanks for the great skin Mx10.
