MX HD HiColor(True 32 bits + alpha)
Unlikely no way to have on it the big picon, but like always MX's on the TOP
:thanks: and Merry Christmas and Happy New Year for all VU+ lovers
The problem with a big Picone is you have to have wide OSD (twenty lines more)
and that I do not like.
Small OSD is only 116 lines wide including a progress bar.
Merry Christmas and Happy New Year my friend.
little attention
TEST V2
MX HC2 Hi Color 1.7.9
Normally I do not set/put the skin files on the forum
but this time only for the test,(Later, I'll put on our image server)
because it is very important.
I would like you to compare speed off the same skin on the server
with this one on the forum .
I think this is a big shift and acceleration for Hi color skins
I would like to hear your opinion and the impression.
Especially test big panels.
Thanks.
If you do not know
Skin can be manually installed
copy/FTP file to / tmp
and
Green >> Yellow >> Manual install BH packges
AGN
We testing the difference in speed from the
skin MX HC2 Hi Color 1.7.9
on the server and this one.
FILE DELETED skin on the server for download.
little attention
TEST V2
Thanks.
If you do not know
and
AGN
Tested on Vu+ Uno BH 1.7.9 , It's more Faster than previous one , It works fluently and the change is very obvious , Thanks so much Matrix10 :)
Nice clear, very easy to read in menus. Infobar is clear too, with exception of the on/off status next to clock "dolby/ratio/text tv" etc. Those lighted are easy to see, but i find it difficult to read those who arent lit. Ofcourse this is a good contrast, no doubt of what is on and not, but in my oppinion the ones in off state could be a little brighter(or drop shadowed) and thereby easier to read. No big deal though, just a little detail. Speed is ok (VU+ Solo1). I cant document it, but it is my impressions that it is only a tad slower than default skin in 1.7.9 , it is very usable and browsing and zapping is fluint,with only tiny delays.
I used Eclipse_HD_C_HC before this,but ill go with this for now.
Good work
MX_HC2_BH1.7.9_VU_V2_bh
Good work
Both thanks,
Excellent comments
I'm glad that the skin is usable on VUsolo 1
because the graphics are a bit heavier and HI color
For me it is important that I found one of the causes
which slowing down skin .
In general, skin is not that important but the problem that has been working with HI color graphics.
Skin is good , and a personal choice.
Thanks agn
Rgd MX
