Hi , is it possible have second infobar with this skin ?
This is a great material design skin.
Glad you are now fully adopting this style for your new skins.
hi Matrix10
at the beginning of thanks for your work
I found a small mistake, a lack of
arrow to the right or left
we see it
press the menu buton
change the view mode text
select a single epg
and we have such an effect
fix it this shortcoming?
my reciveris Vu + Duo
irritates me is the number of heads ABCDEFGHIJK can I change this? I just ABC
Regards
hi Matrix10
You do not see ?
Lack of graphics MX HQ10, displays a graphic of the skin of the default MX HQ9W
Regards
hi Matrix10
You do not see ?
Regards
If i choose "show channel number in infobar - NO" (under osd settings menu) - the channel number stills there. Is it possible to remove it?
regards
